Default view quality for drawings?
Hi All,
When creating a drawing, I find that the views Onshape generates are set to Best Performance. Unfortunately, that gives incomplete views that are often even inaccurate or include impossible geometry like open points between lines and curves. Forget about it for anything with a properly modeled thread. Those drawings make Onshape look like it's one of those artists progressing through dementia. I'm sure it's fine for someone doing a print of their rectangular cabinet panel with a few drill holes.
So I always have to manually go through setting EVERY view to a Best Quality render that I can actually dimension off of.
Is there a way to tell Onshape to always just do Best Quality for drawing views?
Hi @Tru7h, I'm not sure of a way to change the default, however you can change multiple at one time by selecting them with a box selection then right clicking one of them.
