variable default value with MIN and MAX for length input
How can I specify a default value for a length input and also specify a minimum and maximum value? The values are again dependent on a previously made selection.
I found the defineLengthTolerance command in hole.fs, but I can't reproduce it.
That LENGTH_BOUNDS is just a map, and you can write your own. For example:
