Variable Section Body FS, no edges on faces
samuel_l
Member Posts: 6 PRO
Hello everyone,
I am using the variable section body FS to do a sweep on a 3D curve and keep my section normal to a plane, because the normal sweep feature keeps twisting the face just a little bit (about 1 degree).
The problem I am having is that there are no edges on the part faces, so it's hard to work on the part because I can't use faces as planes for sketches or other operations.
With the custom feature
Normal sweep
Is there a way to create edges so that the flat faces are useable as planes?
Is there an other tool to make sweeps with a reference direction that could do the trick?
Thank you,
Normal sweep
Thank you,
https://cad.onshape.com/documents/c1316b12bb5e2357e6c48c1c/w/5e851077bed385739460a54d/e/70eda57b096005e2bab71d96
@S1mon
I was just wondering, would a sweep with the section normal to the right plane be simpler if the option existed?
Thanks again it works great,
I'm not exactly sure what you mean by "simpler", but in general, Sweep behaves best with the Section normal to the Path. In other CAD systems, having a point on the section which pierces the path is usually a good idea (or even required). I'm not sure if it makes much difference in Onshape, but I usually do it out of habit. You can break both of these rules, but it may make things more complex.
In Onshape, the sweep section doesn't have to be at one end or the other of the path. I sketched my "Sketch 1" on the Front plane for "Sweep 1".
https://cad.onshape.com/documents/1d4e9076b16f1ac59d74d99a/w/9296fcba859140baec43f7b4/e/fe64119313073f5c2714ae60
https://cad.onshape.com/documents/eb9428b5809b060a0a454f36/w/99a7824647c8ddf8a0f56be0/e/5f2f2a15ec1369adb4c5c002
So there’s four methods ——
Because TEST only has one face at top and bottom also, it will take more time to get an understanding of what’s going on with it
The other three — I started by looking for parallel faces
Of those three, none of them were completely parallel from end to end
But one was more parallel than the others
And that’s the last one — EXTRUDE then THICKEN (herein ET)
On a cursory visual inspection, comparing TEST against ET, it seems that TEST is pretty close to ET. Now being as ET has faces on the left and right that are parallel, well this shows that there is no twist in ET. So if TEST is fairly close to ET, then it makes me wonder where that one degree twist is in TEST
I took a little closer look at things
TEST is not going to hack it. Because upon splitting the face (see GIF below this paragraph) I ended up with non-planar faces. Deduced from the fact that I was not able to use those faces created by the splits for sketches
As for the other two parts, the one made with SWEEP and the one made with SWEEP then THICKEN, they both have faces that are not parallel as demonstrated in a GIF in the above message.
For best results, use the EXTRUDE then THICKEN method.
