Fillet in active sheet metal
Hi yall,
why cant I create a fillet in an active sheet metal?
Best regards,
Axel Kollmenter
Axel Kollmenter
glen_dewsbury Member Posts: 1,120 PRO
Where are you trying add fillets on your sheet metal parts?
Against a bend, OS doesn't know what to do.
If in flat view OS may be trying add material for an inside radius. Doesn't work. Only subtract in flat view.
https://cad.onshape.com/documents/eeff86f87f2b3be9ae6915b8/w/c75821c5084576f01fba38b9/e/1cea5dc353dd578472a69be2
1 -
Axel_Kollmenter Member, pcbaevp Posts: 431 PRO
Ah ok I got it... you have to set the fillet-setting to "Distance"The default is set to "curvature" (Krümmung)
Best regards,
Axel Kollmenter0
Axel Kollmenter
It should always default to radius!
There are other tools which I wish would have defaults which made more sense for the scale of object. On something small and hand-held, the default extrude distance is often too much, and the default is even more absurd for move boundary.
The opposite is true if you're working on something the size of a car or architectural.
I don't think per "document" would be very useful, but by "tab" would could be a good alternative as well.
Yeah thats kinda confusing.
Per session is a very good idea in my opinion.
Axel Kollmenter
It might actually work somewhat if you mapped either one to the same variable after but there might be some complications with manipulators etc...
That said I'm sure they could add "in the background". Maybe even add different "UIHint" options for persistent/session/user (i.e. checkbox), etc...
