row of holes / repeat shape
henning_michel_henning_michel_ Member Posts: 19 EDU
Hi, how do I generate a row of 20 holes of the same diameter without drawing and extruding it 20 times? I am looking for a function that might be called 'repeat shape'. Thanks Henning
  • eric_pestyeric_pesty Member Posts: 2,126 PRO
    It's called linear pattern.
  • henning_michel_henning_michel_ Member Posts: 19 EDU
    Thanks Eric, found the button. But it seems like I can only repeat a shape that consists of material, not a shape defined by not consisting of material, like a hole?!
    @henning_michel_
    You might want to go through some of the training to learn about the different modes of the different features... (looking up the help topic is always a good option too...).
    Hint: look at the very top of the feature dialogue.
