Incorrect simulation result
Florian_Wirth
Member Posts: 4 ✭
I simulated a simple beam bending ( fixed on one side and normal force on one side) and calculated it. Although this should be a simple simulation, the displacement values do not match by far. (Calculated: 0.45mm, Simulation: 0.17mm)
Why is this?
https://cad.onshape.com/documents/1696e7025146ed6e841ccf69/w/d4ed85429e4c48f0c848c797/e/c8ab7e124ee9fb708e03de77
