Constrain circles into circles
roland_koeckelroland_koeckel Member Posts: 11
Hello
I need to constrain circles into circles.
The diameter of the smaller circles is given put the position can be arbitrary.
The diameter of the bigger circles needs to be defined by the position of the small circles.
The small circles should always be within the bigger outer and inner circle.
The small circle closest to the center point should be tangend to the bigger inner circle
The small circle further away from the center point should be tangend to the bigger outer circle
Can this be done only with construction geometry and constrains?
https://cad.onshape.com/documents/349d77b05485db820938a6f5/w/dc3f9c2818549fe069a0f467/e/0e74713bf67de9a72314838e
  • roland_koeckelroland_koeckel Member Posts: 11
    @dirk_van_der_vaart
    Thanks for your comment. Unfortunately this is not what I mean. There should be no hard dimensions for the bigger circles. These dimensions should be defined by the position and dimensions of the small circles. The inner circle should be tangent to the small circle that is more close to the center point. The outer circle should be tangent to the small circle that is further away from the center point
  • S1monS1mon Member Posts: 3,745 PRO
    edited February 2023
    This is either a really simple problem, or there's something else that you want that is not clear. I just added two tangent relations to your sketch. If you constrain the centers of the larger two circles (which you already did to the origin) and you constrain the location and diameters of the small circles (currently 15 and 16mm diam), then the sketch would be fully constrained.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    You start off by saying you want circles constrained into circles. You said you did not want the big circles to have dimensions themselves, but you did want them to be defined by the smaller circles . And you talked about position.
    So I interpret this as if you’re wanting a fully constrained sketch where all the lines are black. Yet everything is adjustable. But no radius or diameter dimensions on the big circles themselves
    You wanted to do it with only constraints. So it should be realized that dimensions are considered constraints
    In the document below, adjust any of the dimensions including the angular dimensions to see if this is what you were looking for
