assembly mate
parviz_aghayarov072parviz_aghayarov072 Member Posts: 7 EDU
hi friends .please help me make concentric mate (which i made ) which shown picture
  • Prasad_KhistiPrasad_Khisti Member Posts: 2
    As far as Onshape is concerned there is no concentric mate or axial alignment. You can use revolute mate here based on your operation that these two disc should rotate relatively.if you can elaborate more about where you stuck up will help to give you better solution
