Can't scale a part on the Z axis
peta_lab
Member Posts: 7 ✭
Hello, I'm pretty new to OnShape as a whole, but I've spent some months trying to get the basics down to a point where I feel I'm somewhat confident with the program. That being said, I just found a very weird constraint that doesn't allow me to continue with a project I'm currently working on. The issue went as follows:
I guess my best hypothesis now is that the surface I'm trying to upscale now is somehow linked to another surface of ridiculously small size that's floating above it, and so every time I try to upscale it past twice its original size it might force OnShape's 3D rendering program to overflow, which in turn prevents me from completing the upscaling. Any and all tips would be greatly appreciated, as I don't want so many hours of work to go to waste (or to re-do them for that matter).
EDIT: I gave up in the end and decided to re-do the cleanup process for that specific model, which allowed me to optimize it a bit more. Guess the reason behind this weird error will remain a mystery...
- I downloaded several STL files and imported them as parts in separate Part Studios, but all gathered in the same project, as each STL needed to be "cleaned up" and then saved as a composite part (by "cleaning up" I mean taking a full body model of a character and turning it into a bust using several methods).
- I saved each character model as different composite parts and then gathered them all in a new Part Studio to figure out some proportions I needed for additional parts.
- I tried to resize all composite parts to 2.75 times their original size, but it wouldn't let me.
- I tried going through each composite part individually and discovered that the only one that wouldn't be resized was one in particular.
- I went back to that composite part's studio and tried to scale it up from there, to no avail.
- I divided the composite part and tried to scale up each individual surface and part, until I found out that the culprit was a single surface that wouldn't scale up to anything over 2 times its original size.
- I tried scaling said surface up in the X, Y and Z axis separatedly and found out that the only axis that didn't allow resizing properly was the Z one.
- I moved the part around and tried again, to no avail.
- I came here looking for answers.
