Why are my spheres printing as hollowed when they're not?
hailey_nealhailey_neal Member Posts: 5
I'm making a molecule, and I need my spheres for each atom to be solid. The problem is: I've made the solid. The program showed them as solid. However, when I go to print it, they're only shells. What am I doing wrong? How do I fix this? *I need this done by the 9th!*
  • _anton_anton Member, Onshape Employees Posts: 432
    edited March 2023
    It's likely that either they're spherical surfaces (or very thin hollow solids) in Onshape or your slicer isn't generating infill. In the parts list, do you see them under "Parts" or "Surfaces"? And, in your slicer, do you see infill being generated for intermediate layers?
  • suzi_grossmansuzi_grossman Member Posts: 11
    Are you 3D printing? Maybe depends on how you are slicing before printing?
  • hailey_nealhailey_neal Member Posts: 5
    It's listed in parts, and I am 3D printing it, but my teacher is the one doing it. I'm not sure how it's slicing it.
    Check the cross-section of the part: https://cad.onshape.com/help/Content/moving.htm?cshid=section_view#View
    If the cross-section is solid (left), then it's a solid part and something's likely wrong in the print step. On the right is a thin spherical shell, which would print hollow.
    If your prints are small, it could be that the infill is too sparse.
    They're solid, so it's probably the printer. I'll make sure nothing's going wrong there. Thank you!
