Retrieving data from cut list for a BOM.
glen_dewsburyglen_dewsbury Member Posts: 1,307 PRO
I have a custom BOM for a very fussy vendor that will only quote if exported for him to use in his Excel sheet. Until recently most of the data had to be added manually. With changes to OS over the last while only one item still can't be retrieved automatically.
Is there a way to get the length provided in frame cut list into the BOM?
  • MichaelPascoeMichaelPascoe Member Posts: 2,824 PRO
    You can access the attributes created with the frames cut list. See the Table custom feature as an example of this. You could then assign it to a property that is shown in the BOM.
    RENDERCAD
  • glen_dewsburyglen_dewsbury Member Posts: 1,307 PRO
    Thank you @MichaelPascoe. I will give this a go this afternoon.
