Drawings/create API
shawn_crocker
Member, OS Professional Posts: 812 PRO
in General
I have been adding some functionality to an app that allows a user to initiate the creation of a new drawing of a selected item from within the app. Seems to be working really good. Only thing is I cannot seem to get the new drawing to get created using a selected template. See image.
I have templates and I have supplied the appropriate details to the highlight keys in the image. But still, the drawing is created with a default onshape template. When I use the "templateName" key, the query reruns a 400. When I omit that key it works. I'm thinking I am not understanding exactly what should go into the key. Does anyone have any ideas? I know drawings endpoint are supposedly not fully stable and it is not completely suggested to use them but I am hoping someone out there figured out how to make the template part work. It would be so perfect to be able to stop manually changing the template every time.
Optionsshawn_crocker Member, OS Professional Posts: 812 PROJust figured it out. I tried using "templateWorkspaceId". Now the drawing gets created with the right template. It is strange the versionId doesn't work. Based on how the system works as a whole, I am surprise we are even able to reference the workspace like this.0
I have been doing that. I am currently using it without the "templateName" key. Everything runs as expected except the newly created drawing is set with a default template. This is the issue. That the template I am choosing does not seem to be getting read by the server or something.
