Split part showing up in Cura Slicer as whole part
tony_henrietony_henrie Member Posts: 4
I created a part that was too large for the capacity of my print bed, so I split the part and designed a means of indexing the two halves to be glued together. The studio shows "Part 1" and Part 2", but when I export them as .stl files and load them into Cura, they each show up as the whole part. What am I doing wrong?
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 482 PRO
    You probably exported the whole PartStudio.
    Try a right click on the part name in the list on the left side. There you can export each part separatly.
