Where can I set the strength properties for my custom material library?
1
You can do it from within the "assign material" dialogue under "custom" but that doesn't let you add it to the library so you'd have to do it manually every time!
I do note a distinct lack of important columns in this tech tip and video.
The help is a little confusing:
The standard library has columns for all the values:
When I export the .CSV, there are columns and values for all strengths. Presumably, if I add a custom library in this format then I would be able to get the right info in?
https://forum.onshape.com/discussion/20518/enable-strengths-in-custom-materials
