[Request] Add Single-Sided Limits to Hole Wizard Tolerances
in Drawings
Hello,
I'd like to request the addition of single-sided (unilateral) tolerance limits into the Hole Wizard tool. Adding in tolerances to the Hole Wizard was great and helps simplify things by not having to always call out tolerances for hole features. I use single-sided limit tolerances all the time for precision clearance locating holes and it would be nice to have the tolerance ready for callout in the drawing instead of having to manually enter it.
Another thing that could be useful is the addition of hole/shaft tolerances which I think is per ISO: 286-2 (ex. h6/H7).
Improvements to Onshape - March 20th, 2023 — Onshape
