conical hole from radius and apex angle
mark_nahabedianmark_nahabedian Member Posts: 31
I want to make a conical hole in a part.
I have a sketch plane perpendicular to the surface that will host the base of the cone.
I'm trying to define a right triangle to revolve to form the cone.
I have a line that defines the radius at the base of the cone.
I have a variable defining the cone's apex angle.
I can use trig to calculate the length of the other leg of the right triangle to form the altitude of the code.
I don't know how to tell OnShape that "the length of this line is the length of that line times the cotangent of the angle in that variable."
Suggestions?
Thanks.
  • eric_pestyeric_pesty Member Posts: 2,275 PRO
    I'm confused...
    Does the sketch in the example linked above not achieve what you are trying to do?
    You could do it the "hard" way by using equations either in a variable or in a dimension box but I don't understand why you would need/want to do this...
