BOOLEAN OPERATION FAILED TO RETURN A VALID PART
dillon_catenacci
Member Posts: 7 ✭
I'm trying to make a rim and when I try to use a boolean on all the parts and target them into Part 2, it doesn't let me click on 3 of the parts that I'm trying to select without giving me an error message saying "Boolean Operation failed to return a valid part." What am I doing wrong, and how do I fix this.
https://cad.onshape.com/documents/98ced53a22a208a75937169c/w/bdb811229d90eb8f587c652a/e/589423509d2a5753071245ca
Thanks in advance!
Thanks in advance!
If you want your wheel to be manufacturable or even 3D printed, you probably need a little more material where all the spiky shapes come together.
https://forum.onshape.com/discussion/20585/better-error-handling-and-training-around-zero-thickness-parasolid-limits
