Anyone recommended how to achieve different configurations of a Part or Asm in a linear array
I will need to pattern a component. However, the component will have a variety of configurations ( number of holes and suchlike) What is the recommended technique to achieve this because I cannot seem to see how to change the individual parts configurations if they are part of a pattern. They all take their configuration from the seed part.
www.naturalshelter.com https://www.linkedin.com/in/digitalnaturedesign
https://forum.onshape.com/discussion/8452/configure-instances-of-assembly-patterns
And then insert the partstudio in your Assembly
