extruding not working
chloe_chen866chloe_chen866 Member Posts: 7 EDU
Hello, this is a follow up to my previous question. I clicked 'new' but it didn't do anything
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,583 PRO
    edited April 2023 Answer ✓
    You are trying to create "zero thickness" geometry between the L and A that is preventing the extrude from working:
    This comes up quite regularly... If you search "extrude fails" you will find lots of threads discussing it...
    https://forum.onshape.com/search?Search=extrude+fails
