RIV NUTS - Where are they? M4 - M12.
hugh_rousehugh_rouse Member Posts: 8 PRO
Hi team,
Does anyone know where the Riv nuts are? I can't seem to find M8.
This Pem fastener system seems pretty average.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    PEM fasteners are not the same as Rivnuts. They are pressed into sheetmetal, cold forming the sheetmetal around the PEM nut/standoff/stud. Rivnuts are riveted in place. I don't believe Rivnuts are built into Onshape. You would need to download them from the vendor, or probably a better source is McMaster-Carr.
  • hugh_rousehugh_rouse Member Posts: 8 PRO
    Nick Thank you.
    Appreciate your input on this.
