is it possible to pattern a part (eg a screw) using a set of holes as the source of the pattern
paul_mcgivenpaul_mcgiven Member Posts: 13 ✭✭
in other major CAD system that i use professionally (CATIA V6, Solid works Solid edge etc) you have the ability to insert a screw into an existing hole pattern and or copy a part with mates
is there a method of doing this with onshape ?
i currently have to copy and paste a screw then mate it for every single hole
