How to get feature dependencies via script?
felix_hahnlein
Member Posts: 4 EDU
In the UI, you can see what preceding features a certain feature depends on.
How do you get that information via the REST API or a featurescript evaluation call?
Thanks in advance
caden_armstrong2
Member, User Group Leader Posts: 121 ✭✭✭
Short answer: no.
Long answer:
You could- Get the IDs of all selected geometry from the parameters of your selected feature
- Traverse the feature list, getting the feature id for each feature
- running an "EvaluateFeatureScript" query in the API, looking at qCreatedBy(featureId)
Evaluate the results of that qcreatedby, and look at all of the geometry IDs, if any match your step 1 Ids, you have a dependency - If you only want 1st level dependencies, stop there
If you want the whole list of dependencies (dependencies of dependencies), you then repeat the process for any dependent features until you run down the list
0 - Get the IDs of all selected geometry from the parameters of your selected feature
Long answer:
You could
Not an easy process, but possible...Evaluate the results of that qcreatedby, and look at all of the geometry IDs, if any match your step 1 Ids, you have a dependency
- EvaluateFeatureScript will evaluate the featurescript with the rollbackbar-index indicated by the REST API call. The rollbackbar is at the end of the document by default. That means that geometric entities which have been used and effectively deleted by intermediate features, won't be returned. I think that in the official python onshape-client package, the rollbackbar parameter has not been exposed for the eval_featurescript function. I had to modify that part of the code to pass it through.
- qCreatedBy will return the Id of newly created, but not of modified geometry. However, modified Brep entities will get a new geometryId which can be referenced by features. So in order to trace which geometryIds have been "created" by which operation, you have to call qCreatedBy at every step of the feature list also for all preceding features. It's a double loop, so we call qCreatedBy O(n^2) times, where n is the total number of features.
At least that's how I got it to work in the end. I'm open to suggestionsA less elegant solution, but might be effective.
