ISO 9001 Document Management
Hi All,
I am very much in favour of moving everything to the cloud or SaaS, and Onshape is an outstanding example.
I wondered if any working to ISO 9001 would share how they work with their document management.
Do you use SaaS/Software or a traditional network folder structure (word documents saved in a Quality folder) to manage policies, procedures, work instructions etc?
My initial thoughts were the management through Onshape. As you mentioned, most people using it would be non-cad users. I had the same thought process as you. With auditors looking too deep into it, it could open up a can of worms.
As for google drive/docs, I was unaware you could lock things down. I used Gmail for my freelance business and I haven't dived into sheets/docs very much. Traditional Word/excel is still heavily used in the day job.
My research sent me towards cloud apps, which all seemed to have hefty price tags. I also looked into eQMS, which seems all-medical basis and follows the medical standards but nothing for 9001.
https://www.ptc.com/en/products/arena
It's also SaaS and it happens to be a great PLM tool, if that's something you also need....
As a single-person company wanting to bring a product to market, I was not entertained. The PTC/Arena sales team would not discuss anything in great detail (I didn't even get a demo) because it was clear I was not a big fish and was pushed more to go through the day job (the bigger fish). I even asked what the minimum number of uses needed to run correctly, and they could/would not tell me. I was expecting maybe two users to be required. I through.
As an engineer at my day job (manufacturing), I have a lot of obstacles and approvals before the software can be integrated. With the likely
From my research, it seems there is a gap in the market for a piece of eQMS/ePLM software for a one or two-person company starting with a product line and wanting to integrate a piece of software at the ground level, then being able to expand into it and add users, if needed.
Our company also used google docs - but it still had some functionality gaps at the time.
For better or worse, Sharepoint seemed like the most reasonable option for a small team. It requires a lot of setup and customization to get what you want, but the cost is reasonable.
The good thing about onshape is that you can get static links to specific versions. So, even if design content lives in Onshape, you can copy links to your other documents as needed.
For a little more money (min $500/month for 20 users) you could look at Cognidox - they have pretty good integrations with MS office tools. This would be a step above sharepoint in terms of ease-of-use (and require less configuration, potentially). Pricing Page | Cognidox Lean Document Management System
Thank you, @tim_hess some great information, and I hadn't thought about using Onshape links in documents.
