Setting Comma as Decimal Separator in Onshape
in General
How can I configure Onshape to use a comma as the decimal separator? I
haven't been able to locate the option and the older threads I found
didn't provide a solution. I am using a German keyboard.
1
David_YL_Nguyen Member, Onshape Employees Posts: 178
Hey Amin,
Currently that is not possible but should hopefully come soon.
You can add your vote to this improvement request to help highlight the issue: https://forum.onshape.com/discussion/18236/comma-dot-decimal-denoting3
You can now use comma as a separator since the latest release: https://forum.onshape.com/discussion/20801/improvements-to-onshape-april-28th-2023#latest
Enjoy!
