Sheet Metal with Bends - Best Practice
john_hauck
Member Posts: 54 PRO
I'm looking for the best practices to make a sheet metal part like this:
Here is my document that creates the part in a less-than-satisfying way:
https://cad.onshape.com/documents/c9b1947c91de47696bc70390/w/d4bd0e8f4b3552a78bf7c120/e/34bb678ad7e318efe9ff8cbe?renderMode=0&uiState=6449297d8d70874f3a187292
I think the solution is to make surfaces of the desired part and then use Sheet Metal, Convert, with Bends - but I cannot get the bends to select.
In any case, what is your most elegant way to make this?
eric_pesty
Member Posts: 2,394 PRO
This isn't a bad way to approach it, the only step you were missing was to boolean the surfaces together before doing a "thicken". You also don't need to use so many mirror features:
https://cad.onshape.com/documents/f0f01ef62e70e845d7d317b1/w/c409a154e0c8c0d97d26cbca/e/112da03a9e0b21626471d25b
1 -
eric_pesty
Also wanted to add:
An alternate method would be to use the "sheet metal fold" Featurescript, which does make this simpler (see alternate method folder in doc above):
https://cad.onshape.com/documents/9f116620b0f6d04445f57293/v/2df4f2beeec4dae0b92bdf58/e/de11451baedbaa3f6c9bae51
1
Bingo!
Thanks a ton!
I've been chided for using mirrors too much in the past too. Maybe I'm narcissistic?
The mirrors aren't "wrong" but you were just making your life harder! And since you needed to boolean stuff anyway, mirroring the different surfaces in one go with the "new" option is just less features and clicks than creating multiple mirrors with "add".
When the actual part is symmetric I usually prefer to just mirror it at the end.
Also in this case if using the "fold" method. The simplest would be to mirror the sketch (probably just once to create half the part but with both flanges at the same time, but also could do the whole thing at once). Then do the thicken sheet metal and add the two fold features (using the lines in the sketch for the folds), and mirror the part at the end.
Meant to pass this on earlier except I got called way.
@eric_pesty
Was going to use part mirror with one side completed but got an error when I checked add. Is it because of the fold on line function? I've used part mirror of sheet metal before with much more complex models.
https://cad.onshape.com/documents/d8be8f9c1b768560d2efa699/w/b50c2cbd87bdfd9eada2d8e3/e/89cac0c9dc005e4f0bbc20b8
Part mirror is working for me on this (even with the "fold" feature from the "alternate" method)...
The one thing I have noticed is that you always have to manually specify the "merge scope" when doing an "add" mirror of sheet metal (whereas a normal part will automatically populate it with the thing you are mirroring). Does it fail even when you make sure the merge scope is correctly specified (I've forgotten to do this more than once...)?
Tried going back to check the merge scope and also tried changing to merge with all. Still getting an error on the merge with this part..
Very odd... Seems to work for me, or where you trying to do something else?
https://cad.onshape.com/documents/12d528c1259d9ecf7d407b64/w/a94e20cd71fd3992efac2e80/e/64aeaf8da120e5b75c6a0fc3
