Extrude (Remove) mot removing filleted edge
msandeepmsandeep Member Posts: 16
I am trying to remove multiple faces using Extrude/Remove. But one face with filleted sides is not getting removed. What am I doing wrong?
https://cad.onshape.com/documents/ead45850fc1e0a93a9a2c8ce/w/55ff8a653a79f12695bf94b9/e/18d05c5e7806a1449dcf4d0a
  • S1monS1mon Member Posts: 4,056 PRO
    It's not clear from the document where the problem is. Can you share a screenshot with annotations?
  • msandeepmsandeep Member Posts: 16
    I found the problem. I was not selecting all the segments for extrude.
