Sketching and Extruding Cycle
Hi all!
I'm a reasonably new Onshape user, and am in the deep end teaching some 14 year old students their first introduction to onshape. I've created a document called the Sketching and Extruding cycle. It's meant to be a map that allows students to create parts.
I'd love some feedback before we send it off the the graphic designer.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Looks good to me, maybe you want to mention that the view for the 2D Sketch should be normal to the sketch plane via shortcut "n"/view cube or right click.
  • Ste_WilsonSte_Wilson Member Posts: 554 EDU
    That's looking really good! Is it up for borrowing? :)
  • ed__charlwooded__charlwood Member Posts: 9 EDU
    Nice, thanks for sharing!
  • kate_leipold_ritkate_leipold_rit Member Posts: 43 EDU
    I'm not sure why it's a figure 8, or why the numbers go to 5a, 5b etc.
    Have you played around with extruding right from the sketch?  It skips a step and uses the full sketch rather than the sketch loops. There are a lot of options in here - but to make it simple - I'd just make a single loop -
    1-2-3-4-5a-5b-5c-5d.  where there is a shortcut to Extrude from the sketch that takes your from 3 - 5c.
