Dimensions
in Drawings
Why are there different commands for radial and diameter dimensions? There should be a consolidated button. A diameter should appear if the entity is a complete circle and default to a radial dimension if the entity is an arc segment with an additional toggle to convert from one to other if needed.
imagine.create.deliver
