Create Drawing from Part Studio
leecaseyleecasey Member Posts: 36 PRO
Minor thing really, but curious... why isn't there an option to create a drawing from a part studio, when right clicking the tab, but there is for an assembly? Just created an assembly to save a few clicks creating 4 views... first world problems! :)
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 894 ✭✭✭✭✭
    I was always curious about that as well. You can right click on the individual parts and create a drawing within the part studio.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • eric_pestyeric_pesty Member Posts: 2,353 PRO
    There is if you click on a part in the instance list but there isn't a way to insert "all the parts" in one go.
    The workaround for this is to create a composite part and make a drawing of that (if you want all the content of the part studio at once).
    There's a handy featurescript called "composite selected" that can automatically add all the parts in a part studio (if you wanted to have a drawing that always included all the parts without having to manually adding them to a composite).
    https://cad.onshape.com/documents/f2ea26b1b495cdf788cf4a7d/v/125175404987c141abbba5fe/e/fef978324a54d5ac224c99dc
    Bryan Lagrange
  • leecaseyleecasey Member Posts: 36 PRO
    Thanks guys! Found it!
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,014 PRO
    Maybe a dumb question, what would be the use case of making a single drawing for all the parts in a multi-part part studio? And wouldn’t that actually be an assembly anyway, and better served by an assembly drawing?
    How I understand it, use assemblies when there are moving parts. This particular situation was just a basket. No assembly needed but I still need to make a drawing for manufacturing. Hope that clears things up.
