Ad a loffted surface to an extruded part
I am trying to create a model for an exhaust flange that lofts from the port shape to a round tube. I have created the flat flange and the loft section, but I can not get the two pieces to come together as one part. I have tried a couple of different approaches as you can see in the document, but nothing seems to be returning a valid part.
https://cad.onshape.com/documents/cf460d82e18d984d97401c49/w/c8952f7c53812b04bb7d945b/e/6976b14c1262af6e1431cabd?renderMode=0&uiState=64598fe9a11d8e4e151bbee30
Also note that you can use the "connections" in the loft instead of the guide curves.
https://cad.onshape.com/documents/8d280abb276f59b95c03e610/w/b74dd3d051420adfc9699474/e/887edad32e6965267733748a?renderMode=0&uiState=64599d18e72cef35a8d60790
https://cad.onshape.com/documents/8d280abb276f59b95c03e610/w/e696ed0e39b711b6908484b9/e/887edad32e6965267733748a?renderMode=0&uiState=64599d0de72cef35a8d60785
