Suggestions requested for design drawing approach
neil_preston
Member Posts: 12 ✭
in Drawings
Hoping that this post is acceptable. Novice user here, so please be gentle....
I want to try to replicate a part that is no longer available on a 3d printer. It is a latch for a shop vacuum that holds the top down to the cannister. Originally sold by Harbor Freight item #62266. They have no parts available.
This is considerably more complex than anything I have tried to date, and I'm not seeing any obvious method of 'blocking' it out to start.
It doesn't have to be quite as detailed as the original, but it must have the pivot points and axle, and latch ledge at the top of the upper piece.
Any suggestions appreciated!
