Internal Error has occured when using Rest API to assign variables to variable studio
Soham_Sinha
Member Posts: 4 EDU
Hi all!
I am using the Rest API - specifically, the POST method to assign variables to variable studios (url link /variables/d/{did}/w/{wid}/e/{eid}/variables).
I have been following the Glassworks example in the API for the body of the request: (Below is a test example)
However, I keep getting an internal error shown below.
Is there an internal bug here?
I have tested this in other documents - I can create a variable studio using the Rest API, but every time I try to assign variables to the variable studio, the POST fails with a message. "An Internal error has occured"
"description": "test",
"expression": "150 mm",
"name": "date",
"type": "Length"
"message": "An internal error has occurred; support code eab8dbd66b6f662dc1040301",
"supportCode": "eab8dbd66b6f662dc1040301",
"moreInfoUrl": "",
"status": 500,
"code": 0
