Screws won't fit
Hi there,
I saw some videos about screws by now but the screws and nuts wont fit. I'm not sure what I,m missing. I am using the Thread Creator tool.
I tried to assign the exact ISO diameters to screw and nut but they won't fit. now I am trying full mm Numbers but it doesnt look like it will fit.
Thanks and Regards
Thanks and Regards
_anton Member, Onshape Employees Posts: 461
In PLA and PETG, I normally print holes equal to the diameter of the screw (e.g., 4mm for an M4 screw) - then the screw just makes its own threads. If it's a through hole and the screw fastens to something on the other side, I widen the hole by 0.4mm.
I've found that FDM-printing threads isn't terribly practical.0
Keep in mind that 3D prints do not often print the exact dimensions specified. If the threaded hole prints a little undersize and the male thread a little oversize, the former won't fit into the latter.
