Improvements to Onshape - June 12th, 2023
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 213
edited June 2023 in New in Onshape
It's June, time for our 8th(!) update of the year, and this one is big. It includes improvements to nearly all aspects of Onshape, so there should be something for everyone to get excited about! Let's get started.
GENERAL IMPROVEMENTS
TRIM CURVE
You can now trim (or extend) a curve.
https://onshape.wistia.com/medias/fbciox0xc1
VARIABLES IN SKETCH PATTERN INSTANCE COUNTS
You can now assign a Variable to a Sketch pattern instance count.
https://onshape.wistia.com/medias/ka0jegw4jd
STANDARD CONTENT METADATA
You can now edit more properties associated with Standard content. In the past, the only editable properties associated with Standard content were Part number and Description.
https://onshape.wistia.com/medias/v9bqu4nrnf
NEW SKETCH TEXT FONTS
20 New Sketch text fonts have been added with this update. Click "Show" below to see the list.
  1. Allerta
  2. Balthazar
  3. Baumans
  4. Bebas Neue
  5. Comic Neue
  6. Courier Prime
  7. Didact Gothic
  8. M PLUS Rounded 1c
  9. Michroma
  10. Oswald
  11. Poppins
  12. PT Sans
  13. Rajdhani
  14. Roboto
  15. Ropa Sans
  16. Source Sans Pro
  17. Sofia Sans
  18. Orbitron
  19. Inconsolata
  20. Inter
HOLE FEATURE IMPROVEMENTS
New termination conditions have been added to Hole feature including "Up to next" and "Up to entity."
JOIN ADJACENT SURFACES
You will find a new import option to "Join adjacent surfaces." This new option allows you to simplify imported parts with many adjoining surfaces by merging them together during import.
PERFORMANCE INDICATOR IMPROVEMENTS
New icons have been added to the Performance panel to alert you to poorly performing Part Studios.
DRAWING IMPROVEMENTS
DRAWING DIMENSION IMPROVEMENTS
Drawing dimensions with bent leaders now have an adjustable jog point at the bend.
https://onshape.wistia.com/medias/4huhha6dp7
PROFESSIONAL IMPROVEMENTS
NUMBERING SCHEMES
You can now define Numbering schemes and auto-generate Part numbers for Items and Standard content.
https://onshape.wistia.com/medias/rqtai2wi9r
RENDER STUDIO IMPROVEMENTS
NEW RENDER STUDIO APPEARANCES
Nearly 900 new Appearances were added to Render Studio with this update, including many popular and useful new metals, fabrics, paints, and plastics.
https://onshape.wistia.com/medias/g85hrfu28p
TESSELLATION QUALITY
When creating or updating a Render Studio scene, you can now use the per-part tessellation quality set in each part’s Appearance panel in its Part Studio, giving you a greater degree of tessellation quality control. This is the default setting. Prior to this update the Part Studio and Render Studio tessellation settings were independent of each other.
ARENA CONNECTION IMPROVEMENTS
SUPPORT FOR STANDARD CONTENT AND ITEMS
Standard content and Items can now be synced with Arena PLM.
«1
    xTimRicexTimRice Member Posts: 59 PRO
    Wow, that’s a “banger”! Well done team, lots of great stuff.
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
    S1monS1mon Member Posts: 2,392 PRO
    Wow. This is a nice set of improvements which covers many different areas. Looking forward to trying out the curve trim/extend tool and the sketch pattern variable usage as well as the standard content metadata. (and fonts, and rendering materials, and....)
    adam_gearyadam_geary Member, csevp Posts: 37 PRO
    There's a whole lot of stuff I'm going to like using in this one, but one in particular catches my eye. Does "Join adjacent surfaces" mean it can turn all the triangular facets of mesh objects into surfaces?  Even if it's all just flat surfaces with the coplanar ones merged together, that'd be a huge help when importing data from such files.
    MisaelMisael Member Posts: 9 PRO
    love the improvements! looking forward to test the "join adjacent surfaces"
    OSKMOSKM Member Posts: 16 PRO
    Variables in sketch patterns and sketch text font additions are great, will be using those two very regularly.
    Thanks for another great set of updates.
    jelte_steur814jelte_steur814 Member Posts: 78 PRO
    very happy with the 'Trim/Extend' Curve feature!
    I see a great future ahead for this 'Help point' functionality.
    That would also be great in e.g. "split" (to define which one part is the 'original' and which is 'new'.)
    Nath_McCNath_McC Member Posts: 114 PRO
    Outstanding Update. Great work.
    ben_partouchben_partouch Member Posts: 104 PRO
    That's an awesome update. Thank you guys!
    Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 56 PRO
    That Sketch Array was a big deal when I first started using onshape. Awesome to see variables implemented.
    And we're finally starting to see some fonts!!! Is this fore-shadowing??
    e_g_ee_g_e Member Posts: 11 PRO
    Great update!
    The ability to add categories to standard content will be very useful!
    emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 860 ✭✭✭✭✭
    Great improvemets
    Hole feature including "Up to next" and "Up to entity" deserves a video
    Nothing noteworthy in the code review this time ;-)
    Un saludo,
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    Nice updates.
    I like we can now edit all the properties of standard content.
    Except I had to promote one of my users to admin, since that was the only way they could edit now.
    Josiah_HarthcockJosiah_Harthcock Member Posts: 54 PRO
    Great job guys!
    shawn_crockershawn_crocker Member, OS Professional Posts: 814 PRO
    I am soooo glad this is available now!  I have really wanted this since 2020!
    Kyler_WalkerKyler_Walker Member Posts: 183 PRO
    Variables in sketch pattern instance count!  Thank you!
    don_williams909don_williams909 Member Posts: 139 PRO
    <sigh> Still no Arial font.  Great updates otherwise!
    Nick_HolzemNick_Holzem Member Posts: 62 PRO
    Nice rebound!
    partsovenpartsoven Member Posts: 24 PRO
    Great update!
    Jeremy_WinstonJeremy_Winston Member Posts: 2 PRO
    I have been waiting for this ability to modify Onshape drawing dimension leaders for 2+ years now. This is a fantastic change that all engineers at my company are celebrating. To whoever at Onshape prioritizes the updates: please focus on drawings above all else. engineers need greater customization/control of onshape drawings.
    edited June 2023
    On the plus side of this release, the sketch pattern variables are pretty cool. You can do things like delete instances or make elements of them construction and the sketch pattern will remember those changes regardless of the quantity variable. What it can't do is set a dimension to the last element and have that always be the last element regardless of the quantity. You can set up the math to divide an overall length so you can space things nicely.
    MichaelPascoeMichaelPascoe Member Posts: 1,726 PRO
    The Onshape team is on a roll!
    • Variables in Sketch Pattern !
    • New Sketch Text Fonts ! !
    • Numbering Schemes ! ! !
    • New Render Studio Materials ! ! ! !
    CADSharp  -  We make custom features and integrated Onshape apps!   cadsharp.com/featurescripts 💎
    Mark_LugowskiMark_Lugowski Member Posts: 3
    Great update! Thank you. All improvements to drawings are much appreciated! :)
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/blEWuWGt5sI
    Un saludo,
    michael_vanendemichael_vanende Member Posts: 14 PRO
    Nice updates.
    Did they create an improvement request for this? I think it is better to have a permission that you grand to your users.
    philip_7philip_7 Member Posts: 14 ✭✭
    edited June 2023
    Nice updates.
    @john_mcclary - not sure whether you are on Pro or Enterprise, but within Enterprise I have an explicit permissions setting under the Global Permissions menu for this which can be assigned to individuals or groups. I created a new group "Standard Content Managers" for this:
    Lynx_232Lynx_232 Member Posts: 2
    I see some small changes have been added to the hole tool. Those are nice features, but what about hole tolerances in the feature? Being able to add press or clearance dowel tolerances, so they come through in the detailing, is something that is really missing here. Hopefully you guys will be able to add some features like that in the future.
    Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 211
    Nice updates.
    Yes, we're working on it.
    We don't have dowel pins in holes today. It is on the radar for sure.
    Support & QA
    philip_7 said:
    Nice updates.
    Pro, but Onshape support has created a ticket. Thanks
