Two Array > Zip > Key, Value Mapping
Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 117 PRO
I'm trying to carefully approach this one as I don't see an elegant way through at first glance. Given two arrays a and b, sized n, how could you create from them a map like so:
{ a[0]: b[0], a[1]: b[1] }
  • EvanReeseEvanReese Member, Mentor Posts: 2,462 ✭✭✭✭✭
    edited June 2023
    Is your goal to create the map from the arrays or make the arrays from a map or what? Does this do anything you're after?
            const a = [12,15,2,5];
            const b = [3,5,7,9];
            const count = size(a);
            var theMap = {};
            for (var i = 0; i < count; i += 1)
                theMap[a[i]] = b[i];
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 117 PRO
    Yeah that does the job very nicely! I wasn't sure if I was misreading the API for a shorthand of it in method overloads. But this is short enough!
    Cool! good opportunity to write a function if this is something you need to do often.
