Issue filleting file
carmelo_establiercarmelo_establier Member Posts: 2
Hello!
I am fairly new to OnShape, and for my first project, I was trying to create a shape to produce vacuum-formed moulds for chocolate pieces.
I am currently stuck trying to fillet the top of the part, and it seems like, even following tutorials and documentation, I am unable to fillet the top of my shape.
Can you help me figure this one out?
Thank you very much!
  • MichaelPascoeMichaelPascoe Member Posts: 2,772 PRO
    The shape appears to be extruded from an imported vector file. Notice all of the short segments instead of one continuous surface on the sides.
    Try tracing the shape with the Spline sketch feature to create a smooth shape to extrude. This will most likely fix the issue. Feel free to share a link to your document if you need help tracing.
