How to copy an onshape public document using the api and then get the new url of the document?
Hi, I am new to Onshape and need to the following. If I have a public document (such as https://cad.onshape.com/documents/b33a147f86da49879455d286/w/bfdeeceb44a140cfae14fdd1/e/c26b2860c5d143a6a1414663), how can I use the api to make a copy of this and get the new url so I can modify it? I can do this using the UI but I need to do this in a python script using the api. I tried the glasswork explorer but it is giving me bad-request. Any help would be much appreciated.
The sample request in glassworks has some extra fields that aren't required.
To copy that public document you should only need to do:
https://cad.onshape.com/api/documents/b33a147f86da49879455d286/w/bfdeeceb44a140cfae14fdd1/copy
with a body:
{"newName":"my new document name","isPublic":false}
