Assemble angled plates
robin_dvorakrobin_dvorak Member Posts: 12
Hi guys. I don't how to solve this problem. It must be so simple but I cant figure it out. I just need to put together 4 plates which they have angled sides. It should looks like a start of the pyramide but I need to assemble it from 4 pieces.
https://cad.onshape.com/documents/80c9e9b23b5390f2f82990ef/w/d7feb2a63c2a9b931d8ddbbb/e/36c04cda488b8531393a4932?renderMode=0&uiState=649d76b54ef35d2dc04a2d11
Thank you for your time.
Robin
    Matt_ShieldsMatt_Shields Member Posts: 231 PRO
    There are easier ways to make a pyramid in Onshape, like making a solid, shelling it, then splitting it.  But if you want to assemble these sides, you can use the mate connectors along the edge and then add a z-rotation offset of (90-65)/2 degrees.
    I have figured out finally !! THANK YOU
