Looking for someone who can replicate a complex gear for a toy from the 1980's
avo_jeknavorian
Member Posts: 8 ✭
Hello! I have a plastic gear that I am trying to have made so I can print it using my 3d printer. This is a complex gear with various windows and posts.
It's for a toy from the 1980's called the Armatron by Radio Shack / Tandy. It's a robotic arm. I enjoy tinkering and restoring these things, and this gear is something I'd love to have as a file to print.
Is there anyone in the Boston area that would like to attempt this? I have 1 intact gear.
Thank you!
Avo
Thank you!
Avo
Injection molded gears are quite specialized, and you sometimes need the gear pair to replicate the one gear, due to specialized tooth modification made per gear pair. All that said, for a fun time fixing an old toy, you can probably ignore those modifications.
https://www.scribd.com/document/401753119/The-Armatron#
If I had to do this, I would find someone with an optical measuring machine or a CMM to help get the locations of the centers. If you can’t arrange that, I would set up a good camera with a long lens (to reduce distortion) and take a very careful orthogonal view and use that as a picture reference.
If I were retired I'd take this on for you, but you probably don't want to wait that long.
I think your best bet is to see if you can find the same used toy on ebay, and steal the gear out of it.
Or if you want to do it yourself to see if it can work good enough, first you have to find the module of the gear. If the toy was made in the 80's, its probably from Hong Kong or ROC. PROC had just opened their borders for export a few years prior, so might not be made there yet. So its probably metric module gears. Unless, Radio Shack designed it in the USA, and only had it manufactured in HK or ROC but to their design. In that case, it might be imperial based. You can figure that out with gear charts, calipers, and counting the teeth. Then plug that into the onshape spur gear featurescript. Print that out and adjust until it matches your gear exactly. Pressure angle is most likely 20 deg or 14 deg. I don't see any profile shifting by eye, so the featurscript should build you the right shape of the teeth. Then, build the rest of the gear with the bosses for the shafts of the little gears. I'm sure that will take a lot of iterations of measuring, printing, testing, and repeating, to get to fit and mesh right. Especially if all you have to measure it are pin gauges and calipers.
If you pay someone to do it, I think you are looking at 1000 USD minimum, and maybe even no-quotes. Its more if you can find someone to do it as a favor to you for free that has equipment they can measure the gear with, and then model it. An optical comparator can probably also get you the boss locations.
Still a complicated thing to do though, and it will help finding someone with experience building silicon molds, with pins to use for boss ID diameters.
The male pattern part usually survives the mold building process, but there is a chance it could be scrapped.
http://cba.mit.edu/tools/index.html
http://cba.mit.edu/tools/index.html#:~:text=Cutting metal stock-,Instrumentation,-Artec Leo
an even higher-res scanner would probaby be better...
from my experience with a hi-res 3D-Scanner (Einscan Pro 2x, 0.04mm res.) it would take not more than 20 min...
