Why won't line function work?
Hi, I'm following Beginner Tutorial 2/5 Adding Features. I've reopened the document today and selected edit sketch 3.but when I select the line feature it's not letting me create the lines needed for the dovetail being created. What am I not doing or doing wrong? https://cad.onshape.com/documents
Are you sure that you were in edit mode for sketch? Seems to be OK now.
Maybe you were in the original document that was meant to be copied in which case there would be no editing/modification of any sort. Easy to do.
example (lesson1 and lesson1copy)
The share button will become active in the copy you created.
Thanks everyone for your helpful comments. I've now found the Onshape tutorial that I'm working through before returning to the Youtube videos.
