Can't get a smooth fill
I finally figured out how to get a projected curve in the shape of the pieces I want, but I can't get a smooth surface on either of them. Every time I use fill it gives me weird uneven bumps that don't match the curve I need. I don't know if I messed something up, or if I've gone the complete wrong way about modeling these pieces. The projected curves turned out just the way I needed, and the pieces I want to make are that shape but maybe 6mm thick. I'm pretty new to onshape so if there's a better way to achieve this please let me know.
Extrude surface
Use projected curve to split each face of the surface.
Delete the split faces using the delete face feature.
Link to copied document
https://cad.onshape.com/documents/453700dd56590202617b68be/w/3d85318a0b555a063e70b99b/e/f03dec111e210b5c35a929b5
