[SOLVED] Sweep not sticking with dynamically generated sketch plane position
leecaseyleecasey Member Posts: 36 PRO
edited July 2023 in General
So, I have this coil model, I need to allow input for the amount of turns. The top turn (grey) is different to the rest due to the "tail" part. I created a plane to sketch this top part on and created a formula to dynamically generate its height so that the top turn was always on top (#Turns*#Pitch). The plane moves but the sweep does not move with it. Does anyone know how I can achieve this?
How it should look:
What happens when I increase the Turns.... the sketch plane moves to where it should be but the sweep that references it does not.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 259 image
    @leecasey Can you post a link to your document and share it as public?
  • eric_pestyeric_pesty Member Posts: 2,379 PRO
    My first thought would be to have the sweep go to the end and use a "move face" to create the tail.
    Otherwise you could locate the start of the tail using an equation and/or variables that use the number of turns etc.
  • leecaseyleecasey Member Posts: 36 PRO
    Support figured out why it wasn't moving with the plane. The section (circle) of the sweep was referencing one of the patterned instance members. Thanks for your input guys.
