[SOLVED] Sweep not sticking with dynamically generated sketch plane position
So, I have this coil model, I need to allow input for the amount of turns. The top turn (grey) is different to the rest due to the "tail" part. I created a plane to sketch this top part on and created a formula to dynamically generate its height so that the top turn was always on top (#Turns*#Pitch). The plane moves but the sweep does not move with it. Does anyone know how I can achieve this?
How it should look:
What happens when I increase the Turns.... the sketch plane moves to where it should be but the sweep that references it does not.
How it should look:
Otherwise you could locate the start of the tail using an equation and/or variables that use the number of turns etc.
