help with rams / hydraulic cylinders
kevin_mason558
Member Posts: 67 PRO
i am trying to develop a lift in work. i have drawn a plate that rotates on hinges, also added in a ram in assembly mode.
just to test positions of where the ram may be mounted.
used a revolute mate for the plate/frame. that moves as id like
used a sliding mate for the ram that moves in and out
But positioning revolute mates on the ends of the rams does not allow for the ram to be joined to the plate and then extend along using the sliding mate (i haven't made brackets yet because i need to test the positions first to see where the ram will work. i can fabricate brackets to suit at a later stage.
hope this makes sense?
can anyone help with this please
https://cad.onshape.com/documents/dcdc6a1fee7cd38ee55e6fe1/w/5e0d04c60fe635665eb9c535/e/f7a107d8b516d60944829b9f?renderMode=0&uiState=64b05ad040fb7f3a624b5c07
@kevin_mason558
Can you make your document public so a copy can be made?
This looks straight forward but easier to demonstrate in document.
I think I have made it public now
thanks
I just cannot get them to mate without throwing up errors and separating other mates
Also I noticed you have a bunch of explicit mate connectors defined at the assembly level but most of these are exactly the same as "implicit" ones so don't really add any value (i.e. it seems you are making your life harder for no good reason with these!)
One more tip: you have frames and a cut list defined but you inserted individual parts in the part studio and fixed them... An improvements if you need the individual parts in the assembly would be to group them (and fix just one), or an even better option would be insert the composite part instead of individual frame parts in the assembly.
Circle around bin pivot and circle centered on ram "fixed" end going through the ram attachment point and where they intersect is where you want your pivot point
am I putting too many mates on things
was just trying to work out ram positions while we are waiting for delivery
I have been using the parts studio to make a lot of things all building parts off one another
and I was told I should be using assemblies more. So I'm trying to do this. But because I'm trying to do it at home around work
I'm usually trying to model/draw something before it's being made within the next day or two.
I find sometimes a 2D sketch is the best way to figure this out, something like this:
https://cad.onshape.com/documents/9a78a5847cc245caac901d3b/w/9959cac71460a6574b6358d2/e/5cd6f62a8b5feb9a24fd430f?renderMode=0&uiState=64b06d79f5c41c233c6c7822
See here for implicit vs explicit mate connectors: https://cad.onshape.com/help/Content/mateconnector_a.htm?Highlight=mate connector
Eric's discussion about about making a sketch to set your initial motion will get you started quickly.
A few more notable points will help to keep organized.
Changing part names makes it clearer to read as apposed to part1 part1 part1.
You made the cut list. This is good. At the same time a composite part was made for you. Using this in the assembly is recommended since it will bring a single item that that needs no further frame mates and can be used for a weldment drawing with a cut list. Any new features that add parts for the frame should be ahead of the cut list feature.
In my example I used mates with offsets to get cylinder connection points before designing brackets. The example allows you to drag the bin up and down to see end results. Can also animate the revolute mate.
As a design note, I would reverse the cylinder orientation. Putting the cylinder on top with rod below offers greater lift capacity when bin is full and less capacity to return the empty bin. As a bonus the rod seals will be facing down to collect less debris on the seal.
https://cad.onshape.com/documents/19af1201ba47247cd6e69c4e/w/965a946ada42f9fd23679b94/e/a14abaaa29c878336de185a4
