How do I make a 45deg chamfer to a half cylinder
I want to clean-cut half of the cylinder edge by 45 deg. Somethig like this (see the picture). How to do it in the onshape?
KR, Alex
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,471 PRO
    The two easiest options would probably be using a
    Cut extrude (with a triangular sketch) or you could do a split face (with a sketch or just a mate connector) + moveface/rotate
  • alexander_tsybulskyalexander_tsybulsky Member Posts: 7
    Do you mean drawing triangle on a plane, opposite to the part? (it is an option but looks a bit brittle ...)
    And could you give some hint to a youtube or tutorial about option2? I'm quite new to the onshape (in fact I'm designing my 2nd part, before I had some minimal experience with freecad, so I'm not on level zero but ... almost there :)
    If your sketch plane for the triangle references the cylinder (using a mate connector on the cylinder would be a good way to ensure this if you cylinder isn't centered on one of the main planes) it should be fairly robust.
    Here's a quick example of the split/move workflow (I used "realign" for the split mate connector but you could also rotate it 90deg along X if you cylinder is in a weird orientation)
    https://cad.onshape.com/documents/628b8f6747374a48405d71c9/w/0f86188b7e24900cac81e96d/e/839963c7d197fc6e3c1166b8?renderMode=0&uiState=64b19bae695d1875b4ad91fb
  • BenTaylorBenTaylor Member Posts: 51 PRO
    @eric_pesty you could do this with a single split feature. Split the part, selecting the top mate connector. Edit the mate connector > Move > rotate around X by 45°. Then deselect keep both sides, and you have a chamfered cylinder. I'd still choose the sketch + extrude method for the most robust solution, but this eliminates one feature.
    https://cad.onshape.com/documents/7afb15aa2c0fd9661f64efb1/w/46157cb2ae2d51eff49252f0/e/f2ebd53c29336bca169bdb2a
    Ben Taylor
    Lead Mechanical Engineer @ Healing Innovations
    @BenTaylor
    True, you can use the split directly, not sure why I didn't show it like this...
    Also when I know I am going to do something like this, I try to add line segment in a previous sketch if possible to make the mate connector selection quicker (i.e. without needing to rotate/re-align).
    @eric_pesty Thanks, that was what I need!
    @BenTaylor Could you please detail on the last step of your approach? I managed to have this (below) but it does not cut the shape.
    You're almost there - at the top of the Split dialog window, it shows you're splitting the face. You want to select Part and choose the cylinder to split.
    Ben Taylor
    @BenTaylor: Thanks ! 👍
