Extrude Remove Direction in Part Studio and Feature Script
Stormi_Backus
Member Posts: 49 ✭
Hi All,
I am trying to make a Feature Script extrude remove but struggling to control the direction of the removal. So, as Neil Cooke recommends, I tried to model the desired feature in the Part Studio first and I can't do it there either. The goal is to sketch a circle on a face and have the extrude remove all material on the exterior of said circle. As you can see below, I have only succeeded in removing interior material. All of the documentation I've found deals with controlling extrusion direction normal to the sketch plane which, I think, is a little different than this because all of my brute forcing isn't making it work! I also included a screenshot of my current feature studio code. Thank you in advance!!
Otherwise you will need a larger concentric circle to create a region to extrude (haven't used sketch regions much in FS so don't know of the top of my head how you select the region to extrude but there are ways of doing it...)
