stl has software switch for inch or metric....the part was modeled in inch does metric change it
don_bdon_b Member Posts: 152 ✭✭
edited July 2023 in Community Support
stl has software switch for inch or metric....the part was modeled in inch does metric change  the size of the model or in other words does it scale up the stl to what the inch dimensions would be in metric or does it just convert the inch size to metric.....for example 1 inch dim. could be 1mm or 25.4 mm depending on if the model is changed or not
Talking about when I export the file which is where the software switch is
  • don_bdon_b Member Posts: 152 ✭✭
    figured it out and yes the STL is changed
    edited July 2023
    delited
