Is there an easy way to fix an imported model that has faults?
S_Regula
Member Posts: 95 PRO
Hi All,
I have imported a model that includes this shaft which OS is saying has faults. When I cut a section view, I see the red area that is the culprit. Is there an easy way to fix this? I can use the part in another assembly, but it will show up as red in the instance list, and because I'm kind of particular about my assemblies not containing any errors, I would prefer to fix it if there's an easy way to do so.
I've tried the "export to ACIS and re-import" workaround, but it still shows up as faulty when I bring it back in as that file type. TIA!
Does it show several solids (looks like it's creating at least one)?
This will probably take some delete/relace body/faces...
Good point, I'm not sure it is any different. I think if I remember right I got the code from support some years ago when I was trying to fix a import that was really bad. Not sure if the tool "Highlight boundary edges" was around then or not?
