Point on the corner of a cylinder
VoyagerVoyager Member Posts: 19 EDU
Hey, I would like to move the yellow point to the outer edge of the cylinder.
Since I'm on the front plane, it wont work.
How would I achieve it to work on Android?
Thanks!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 585
    The Use tool works in Android.
  • EvanReeseEvanReese Member, Mentor Posts: 2,319 ✭✭✭✭✭
    I think you're looking for the pierce or coincident constraints
    Independent Onshape Consultant | Industrial Designer
