Variables Making Holes
noah_lacorazza
Member Posts: 1 EDU
I am designing a part in which needs a hole every 0.5in. And I would like to apply a variable that can change the length of the part, while also keeping that hole 0.5in away from the ends and one another. How do you think I should go about this?
The rounding and recalculating maybe a bit over the top, but I thought it was fun to include. That way you can input any length you like and it will still work out.
Maybe an example is easier to follow!
https://cad.onshape.com/documents/0582cfeee92c71fb38f9552b/w/06a3d0f80fd2bfd74a9d7904/e/3092b83245527a2d99701ac6
You can obviously drive this different ways, e.g. the target number of holes... basically anything to derive an actual part length that gives you the right end_gaps and spacing.
Also, I've used the center distance between the holes as the measurement, but you can rework this for whatever...
